I bought a Catalina 30 a few months ago. It's original Atomic 4 was replaced with a Universal Diesel by a prior owner. Though I am not certain, I think it is a M-20 2cyl. Pre-purchase, we cruised around the harbor for about an hour and the motor sounded good to me. Post-purchase I had a lot of trouble starting the motor. I enlisted the help of a marina-mate, a lifelong sailor, who has worked on various diesel and gas engines for about 30 years. Once the motor was started, it would surge. We looked for a variety of air leaks, replaced most of the hoses, installed a second fuel pump and new fuel line in front of the fuel filter--replacing the outboard-style primer bulb and line, and of course, replaced the fuel filter too. As the problems persisted, he removed the high pressure fuel pump and inspected and tested it. We replaced both the injectors due to age and leaks. Some times the engine runs well for 30 or 40 minutes, with a slight surge usually present, and just this week it stalled and would not restart. There are no visible leaks of fuel. The batteries are good and all of the electrical system seems to be in working order.
Currently it starts and stalls right away. I have attached an audio clip and some pics in case someone can recognize.
The motor is too tall to fit in the standard engine compartment of the Cat 30. I was told it is a M18, but think maybe it is a M20
Currently, we are thinking the problem may be the fuel pump.
