I have a catalina 30 with an atomic 5411 diesel. The last time we were out I had some wires melt down that were sitting of my exhaust manifold. Upon further inspection I noticed that the exhaust manifold flange is completely corroded and falling apart. Also a bit of water is seeping between the flange and the manifold. It appears that a previous owner was having problems with this as there is JB Weld between the pipe and the flange and which along with rust may be the only thing holding this baby together. My question is what temp should that manifold be approx. Do I have water flow problems? If so any idea where? There seems to be adequate water coming out of the exhaust and none of the water hoses seem to be too warm. Is the manifold clogged? My other question is if I can solve the overheating problem can I get through the summer with this shody patch job and a bit more JB Weld or should I slap down the $200-$800 in parts and replace the manifold/flange? The Manifold seems to be okay but the studs are so corroded I'm not sure if it can be salvaged until I tear into it.
