Atomic 4 troubles?
15
Irwin 30 Monroe - Chicago
Hi everyone, I just took my boat out of winter storage and started the engine up for the first time. It seems like the engine isnt running like it did last year. When the engine is in neutral it runs great and I can rev it up nicely. However, once I put it into gear the engine seems like its choking/putting. It still works, but im not getting much power out of it no matter how much throttle I give it.
Any ideas?
-Cory
RichH
Feb 14, 2005
4,773
Two possible problems ..
1. Dirt accumulation on the emulsion tube inside the carburetor ... a small hollow needle-like device that controls the air/fuel ratio - easily cleaned. Is only active when the engine is under load drawing a LOT of air, is bypassed when the engine is at idle
2. Blown head gasket. A4 will run 'fine' in idle, but when load applied ... chokes, wont 'spin-up' to rpm and then chokes/sputters/then dies. Do compression test.
Jun 23, 2004
4
Catalina 30 Burnham Harbor Chicago
Atomic 4 troubles
I had a similar probelm when I repacked my stuffing box. I tightened the box too tight and it was stalling the engine when I put it in gear.
Another thing to do is lookup Moyer marine on the web. Great resource. Call him, he will give you a lot of information.
Bill Thompson
Catalina 30 TRBS
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Don even talks you through repairs sometimes! Great people!
