Atomic 4, Morse Engine Controls
576
Island Packet IP31 Lake St. Louis, Montreal
My friend has an early '70s C&C35 Mk1 with an A4 and the original dual lever Morse Engine Controls.
The controls do not work very well at this point and require him to keep the trhottle steady with one hand while moving the gear selector.
I'd be interested to hear from anyone who has rebuild or replaced one of these. I've done some searching but have found very little info out there.
He will put in a call to Moyer Marine and ask them as well.
Thank you very much in advance
Matt
NYSail
Jan 6, 2006
3,136
Beneteau 423 Mt. Sinai, NY
The cables have numbers on them. Or you can measure the current ones then match the style on the site. I just changed mine and though the numbers would be on the engine side, however they were stamped on the side that was in the pedestal.
Dec 20, 2011
101
Cal 28 Eagle River
I tossed mine and changed to a single lever and I love it! Al so switched sides to port as to me it feels better with a tiller in my right hand!...Dale
Sep 20, 2013
1
C&C 1972 27 Mk 1 Powell River
Single Lever for Paragon Reversing Gears?
Can I switch to a single lever control with the Atomic 4 Paragon Reversing Gear transmission? I'd love to do so but will it work with having to hold the lever back to keep it in reverse?
Mar 2, 2008
406
Cal 25 mk II T-Bird Marina, West Vancouver
If the fwd/neutral/rev clutch shifter lever is moving the governor setting lever, then the problem is most likely dray between the levers at the pivot. Take it apart, clean, fine emery cloth, adjust the shims and grease. They will work like new. Sounds like you don't need to replace the cables but if you do they are a standard item readily available at all marine supply stores.
CalebD
Jun 27, 2006
1,479
Tartan 27' 1967 Nyack, NY
Single lever shifter works fine with my A4 although you do have to lean on reverse a bit more to get it to kick in.
I like having a separate throttle control; a pull knob or (oldSkoolNeil knows this part name. Something like a "Rheostat Valve").
