At wits end
Jan 23, 2014
70
Hunter H26 Peachland
so I keep getting water in the bilge under the aft bunk. I revealed the speedo and the depth sounder thinking I had the problem licked. I did not fix it. I checked all around under the aft berth and can't see a leak. Any ideas??????
By the way, it's a H26. Thx
Jun 4, 2004
392
Hunter 31 and 25 and fomerly 23.5 Stockton State Park Marina; MO
Hi Willemvan,
I have a 23.5 which is similar. When sailing or motoring water coming in anywhere under the liner ends up under the aft berth.
Some prime areas to check are the water tank vent hole, the drain/fill valve shaft, and the centerboard bracket bolt and up-haul line housing. Put some tissue around all these areas and go for a sail. Then see what comes up soggy.
-na -NA Anywhere USA
When you are not sailing with the boat sitting in the water and not raining, I bet it is bone dry. However when you have people on board standing in the rear, sailing, motoring and so on, water is seen. Look at the bilge area under the rear berth and look at the aft wall separating the rear behind the rear berth wall. Then take a flashlight if you see a stream of water and following it back to the transom area. If so it will be one of two areas either the lower gudgeon or the part bolted on that holds the lower rudder pintel and if not, look at the hull to deck joint which most likely that is it. Then report back here and advise. I bet the marine putty after all these years needs to be repaired between the hull to deck joint at or below the water line which is why I said the above when in use or weight in the cockpit. If not, then I will advise plan b but if it is what I think it is then not a problem to fix. I can advise on that one.
