Return the stainless biners and exchange them for wire gate biners from REI. Much lighter (matters when climbing), effectively corrosion proof (only the wire gate sort), and much smoother action. SS biners are ONLY needed where continuous salt exposure is expected. Even on-deck they are a waste and much less handy.Psst!! Do you need a bosun's chair? The local riggers I use have rock climbing harnesses. I was impressed because I keep feeling like I am falling out of a bosun's chair. Mine looks like this. http://www.rei.com/product/880933/black-diamond-momentum-climbing-harness-mens not promoting REI, just using their link.
I bought stainless steel carbiners and some line to clip my tools to the harness rings. So the tools I am not using at the moment are not falling to the deck. Plus I installed a wrist loop on the lines in case I get fumble fingers at height. Prevents holes in the deck that way. I have spent time just hanging around waiting for the Admiral to hoist up some tool I had forgotten and never got tired.
Food for thought.
Final thought...... post hip replacement surgery I might revert to the "chair". Probably one on the dock so I can watch someone else go up the mast!
It was age dependent for me, when younger I'd use a climbing harness or even a "quickie" harness tied up out of 1 inch webbing. Then I got so my legs (and stuff) got all numb and tingling in 15 minutes so started using a bosun's chair. Harness seems more secure but a chair is just as safe and much more comfortable. QUOTE]
I remembered a training session where we spent some time discussing the time needed for a rescue. When the circulation is cut off serious stuff can happen, suspension trauma or blood unable to get to the heart.
http://www.elcosh.org/document/1795/d000638/Will+My+Safety+Harness+Save+My+Life%3F.html?show_text=1
Try some new harnesses and seats to compare the fit. Some butts don't fit well in either.
All U Get
PS Sorry but OSHA was the quickest I could find.
I thought this too, so I bought a mid priced harness.... and now that I have tried the rock climbing/rappelling harness's I can honestly say they just dont cut it when you need to stay in one place very long. very uncomfortable to hang in.Psst!! Do you need a bosun's chair? The local riggers I use have rock climbing harnesses.
I agree... there are better ways (more expensive) of climbing the mast than being cranked up on a winch, not that using a self tailing winch is such a bad idea, but because anyone who has had to crank a 200lb person up the mast before will be hard to find when it needs to be done againI use an ATN Top Climber to go up. Prefer it as I can sit stand my way up the mast instead of relying on the graces of friends to crank me up. Takes a bit of practice but once you get used to it it's not difficult.
With it pulled very tight on the bottom haven't had a side to side problem and....Like Sumner had mentioned the ladder type climber is another choice. When I first used one the loops kept collapsing making it a challenge to get my foot into each higher or lower loop. That was solved by cutting 6 inch lengths of clear plastic tubing and then slitting them so that they could be slipped over the bottom of the climbing loop. That held the loop open at the lower end. However, the ladder still seemed unsteady because it tended to move from side to side as I climbed up or down. After a climb or two it made a great eBay offering!
We have both a chair and a harness on our big boat. Our bowman is always in the harness because he can wear it while sailing, and if he needs to go up ASAP he's ready and all we need are halyards. It is very secure, and often for fun he will pull himself down headfirst along the forestay. Properly worn, you cannot fall out.I thought this too, so I bought a mid priced harness.... and now that I have tried the rock climbing/rappelling harness's I can honestly say they just dont cut it when you need to stay in one place very long. very uncomfortable to hang in.
