Scott Blahnik
This is a follow-up to my original post re the purchase and installation of an asym. on my 260. I received lots of tips from this site, and wanted to report my results for the archives. ( hence the length of the post, I could have used this info) I ordered the spinnaker from the chandlery, and a "kit" from Hunter Marine. The kit came with:1) a halyard (black) with a clip on the end. This turned out to be the biggest challenge. I tried threading it through using the convenient feeding line to no avail. The bulge created by the whipped knot just wouldn't go through the narrow opening near the top of the mast, so I purchased a bosun's chair, had my brother -in-law crank me up there, and still couldn't force it through! Eventually we stripped the halyard and we able to create a continuous line with no bulge using tape.2) Two blocks which attached easily to the stern seat rails.3) Two sheets for the clew which I just tied on, but considering a clip arrangment. 4)They sent me a double rope clutch to replace the current one, but that wasn't right, I needed a triple. They (Greg at Hunter) kindly swapped it out at no additional charge. I installed it using the same four holes left from when I removed the double ( had to use a crow bar after removing the screws). The triple has six holes, so rather than tap two more holes, I just used the four. Seems good enough. Those screws go deep into metal, real solid.So, finally got to try it all out yesterday. Had a bit of trouble at first (which end up?)...finally attached the Tack (it's labeled) to the pin on the bow roller, raised it up, pulled on the pulley system which operates the sock, and poof, beautiful!Only thing is, I got lines everywhere. I'm holding onto the pulley lines, or it slips down and douses it...I've got crew holding both sheets with very little space to cleat them off, everything is taken, but well worth all the trouble. I'm thinking of attaching a large cleat to the base of the mast...but that line for the pulley system is really thick for tying off, and it makes a continuous circle...could use a hint here if anybody has the experience.Thanks,Scott s/v Hello Dolly
