Asking the important questions - is it wrong to use a silver dollar when stepping the mast?
HanBan
Jan 18, 2018
146
Beneteau Oceanis 323 Pax River NAS
Hello again!
OK, so the mast will be here soon, and I've been told that it's a requirement to place a coin in there when stepping. If I use a liver dollar, will the dissimilar metals cause corrosion?
It's a silly question, however, once again I have no idea what the answer is.
Han
May 20, 2016
3,014
Never saw much corrosion under Dad’s mast which was stepped with Silver Dollars.
Les
Feb 20, 2011
7,995
Hello again!
Han
Supposedly, use a silver dollar of the same vintage as your boat. I doubt any corrosion beyond normal would occur.
I'm not superstitious, just a little stitious.
There are many traditions that sailors and boat owners follow or do not follow. If you can find a silver dollar that matches the age of your boat by all means plant it in at the bottom of the mast. It promises to bring fair winds.
Think about it they used gold doubloons back in the days of sailing ships. That may have been the reason the captain wanted to be the last to leave the ship. He went for the gold.
HanBan
Jan 18, 2018
146
Nice, following your comment, I just bought a 2005 silver dollar on ebay. Thanks!
HanBan
Jan 18, 2018
146
Just bought 2005 silver dollar on ebay - along with a whole bunch of other silver dollars which I shouldn't have bought (but I like coins). You guys are the best.
7,437
Hunter 430 Waveland, MS
Pure Silver is about as good as...
Gold & Platinum
On the sea water corrosion chart.
Jim...
PS: You Aluminum mast shouldn't be a galvanic issue with Silver.
PSS: I am hypo-stitious like @justsomeguy
hypo-stitious
In Other words...
"Substitutious Instead of Hypostitious
Had a thought earlier today…instead of hypostitious it might be better as substitutious. I have had a lot of debates with AI guys who talk about Substitution level, as far as an assumed level at which a simulation is functionally indistinguishable from the original. This ties in to the way that consciousness is anti-mechanism by virtue of its connection to unrepeatable novelty.
Mechanism is about repetition and automation. It is about substituting unconscious activity for personal effort and manual control. Being “substitutious” then, would be to superstitious what the compulsion to reduce everything extraordinary into something ordinary would be to the compulsion to inflate ordinary coincidence to the will of a God." by http://s33light.org/post/65280436197
O'Day 19 Littleton, NH
In Other words...
We should discuss this further.
- Will (Dragonfly)
Gunni
Mar 16, 2010
5,937
You have a deck-stepped mast right? So it has a hollow base and sits on a cast socket attached to your deck. The tradition of placing a coin under the mast is for solid masts keel stepped. Your mast has some small weep holes in the base to drain water that collects inside the mast, you don’t want anything in there that interferes with those weep holes, otherwise you risk pooling and a freeze mast split in the winter. A coin may not compromise the drainage but bird nests can - have your rigger plug all bird-sized holes on your mast, they especially like the slots where your shrouds enter the mast. Aluminum plates will do the job.
Islander Freeport, 41 Ketch Longmont, CO
So the tradition was to use silver, you are supposed to make reasonable homages to the gods. In this case, copper was considered too cheap and gold is too extravagant. We always get a silver dollar, place it in a plastic coin holder (your local coin shop will have these) and tape it to the base of the mast or in the center of the mast step. In my case I have a Canadian silver dollar from the year the admiral was born (1949), since it has a ship on it.
This is purely part of the nautical lore, and goes along with the ship naming and denaming rights which we also take seriously. While we have had many ship naming ceremonies for all of our vessels over the years (Great excuse for a party), I have not been able to find any ceremony surrounding the placing of the silver coin at the mast.
Fair winds,
Appropriate sacrifices are always welcome. You also have to remember as long as it is held in the mast you can claim it was a silver Allen wrench, paying proper homage, you may also claim that since the replacement Allen Wrench cost way more than a dollar but, less than its weight in gold, that you provided a suitable substitute. Its only IF you get demasted and the gods can determine if it was a proper or improper homage, that it really matters.
The only rule to remember is The gods are fickle, and will determine your fate at their whim.
I always believe in being prepared beforehand and trying to ward off any evil before it happens. I have enough issues with trying to run the boat and keep the admiral happy, that I try to take care of the gods issues up front. Sort of like prepping the boat for a long trip. Do what I can to prepare, hope for the best, expecting the worst :)
Fair winds,
Victor
PS: I try to listen to the gods and answer their requests as it does seem t keep me out of trouble when sailing. So, when Neptune asked for my Phillips head screw driver to adjust his trident, I promptly drop it on the deck so that it would land appropriately in his hand as it splashed in the water, to heck with the Winch I was almost finished installing :)
