- Oct 22, 2014
- 24,926
It is that time of year when boat safety gear gets hauled out of storage and carried down to the boat. Mold, dust, and mildew are removed, and the gear is stowed aboard, ready for that first sail.
When did you last check your dates on the PFD inflation system?
Are you sure the tubes that can save your life will inflate?
Have you ever jumped into the water while wearing your PFD?
A recent reading of a Canadian Marine Transportation Safety investigation reminded me of the risks taken by marine workers. The problems they face are no different from those to which we sailors are exposed.
Check your safety equipment. Be assured that it works as expected. If not, correct the problem before you untie the lines and head out on the open waters.
Here is the report: Marine Transportation Safety Investigation Report M22A0332 - Transportation Safety Board of Canada
What I highlight below is the inspection of the PFD worn by the deck crewman.
"During the examination of the occurrence PFD, the expiry date noted on the cap was 2027, and there had been an initial activation of the inflator cap when the water met the water-sensitive element, but the inflator body did not activate. This allowed the inflation activation mechanism inside the inflator cap to rotate. However, the mating gear on the inflator body did not engage and the piercing pin did not move or puncture the CO2 cartridge. The examination and testing determined that the cap and body were unmated. The cap activated and the body did not, indicating that the cap and body were separated at some point prior to the occurrence and not as a result of recovery efforts. Because the inflator cap and inflator body were not mated, the PFD bladder was not sealed, which prevented the PFD from inflating."
