On the C36, in the lazarette, which is quite roomy. On the Tartan 3800, haven't figure that out, yet, but the huge, port side cockpit locker is the likely candidate. And, yes, they should be somewhere you can ge to if you can't go below.I've thought about a gumby suit. Out of curiosity, where do you guys store your two on 35 - 38 ft boats - after cabin with the other stuff? Not knocking the idea, but in a galley fire situation, I'm stuck on deck.
Myth#33 or so says Amerex FireI hate impaction
Do you leave them upside down a while? Shake them?
Never thought of that. Now that you mentioned it, it makes prefect sense. Thanks for highlighting.It's been recommended to upend your dry chemical extinguishers once in a while to reduce possible impaction of the powdery stuff.
I saw that too, although one of their reasons for it being a myth is “the extinguisher will still discharge the agent – even after sitting ... for a year.” I’m not sure what that means for extinguishers that sit for a decade rather than a year.Myth#33 or so says Amerex Fire
http://www.amerex-fire.com/upl/down...-with-a-rubber-mallet-to-fluff-the-chemic.pdf
Who said "turn them upside down and hit them with a rubber mallet?" Nobody here.Myth#33 or so says Amerex Fire
http://www.strikefirstusa.com/2016/03/theres-smoke-theres-fire-extinguisher-ready-emergency/Shake Chemical Fire Extinguishers Once a Month
There are different types of fire extinguishers. The manual will tell you what type you have. Dry chemical extinguishers contain a powdery substance that will settle over time. Make sure you shake these extinguishers once a month to prevent settling.
Everywhere.I like the idea of a fire blanket. So much so that I am going to look online about where to buy one. I'll pass it along when I find it.
I do too! Now wish we had had one for that galley fire.I like the idea of a fire blanket.
Our Fire Marshall just told me shaking fire extinguishers can actually be harmful and don't do it. He explained that it can plug the pickup tube. Have them serviced at least every 10 years or replace them if it's cheaper.It's been recommended to upend your dry chemical extinguishers once in a while to reduce possible impaction of the powdery stuff.
I'm thinking about where the best place to mount it is. My galley is starboard right at the bottom of the companionway steps. We don't cook on board though.Has anyone here installed or used one of these blankets? The container size seems really small ( 200 mm x 170 mm x 30 mm), which is smaller than the size of a small notebook, and it opens to a one meter square. That would fit anywhere.
Your fire marshal probably has stock in the fire suppression industry.Our Fire Marshall just told me shaking fire extinguishers can actually be harmful and don't do it. He explained that it can plug the pickup tube. Have them serviced at least every 10 years or replace them if it's cheaper.
Ken
