Are balsa cored topsides good or bad ?
Cherubini 37c HULL#37 Alameda
Not to be rude but........ I only need the opinions of people who really know about the subject I'm referring to. One in particular who's name rhymes with stew. The rest of you know who you are.
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
Some people have an issue with terminology . . me included. Are you referring to the deck or the hull sides above the waterline?
Definitely the hull sides on this one. I'm concerned about rot, moisture & delamination as the vessel ages and overall strength of construction compared to a solid FRP layup.
Pat, I thought you'd ask this, after I read the link in the last topic and read the boat review.
I personally don't know. It appears that the outside is fiberglass, right? and there should also be an inside liner with the balsa between. With the longevity, so far of these boats, I feel it's not an issue. Looks like a great boat.
With our balsa cored decks (and I KNOW you mean topsides, not the deck) we have had no problems with our 24 year old boat in that regard. Of course, careful bedding helps.
I also think it would be prudent to get in touch with Ted Brewer, the designer, and maybe ask him about his design choice. Have you found a users group for the boat online? My "on-the-top-of-my-reading-pile" Good Old Boat magazine doesn't have an article by Ted. But I suggest you get in touch with GOB magazine, who'd most likely get you in touch with him. Try these: jerry@goodldboat.com or karen@same. They're very helpful.
If that doesn't work, I'll go dig deeper in my stack of GOB magazines (I have all of them!).
Lemme know.
Stu
Ross
Jun 15, 2004
14,693
A proper balsa core has fiberglass bonded to both sides. The only water intrusion would be in the area of fastener holes. Decks will present more of a problem because water can and does lay on them but above the waterline and with well seaded edges rot will not be a problem.
Oct 2, 2006
1,517
Jboat J24 commack
I would say the potential is always there to fail as there is a lot of varation from build to build as to how green the hull is when they put in the core
And theres not a whole lot between the core and doom :)
But in repiaring my boat i used it and feel its the best product
Ross
Jun 15, 2004
14,693
Paulownia wood is a better choice because it is durable and very nearly as light. There is an Australian builder that uses paulownia.
RichH
Feb 14, 2005
4,773
Cored topsides are 'superior' to solid glass in lighter weight but equally as strong and with less 'flexure under load', .... all this because of the 'box beam' construction (higher 'structural moment of Inertia') of the composite. Historically, there 'were' some delamination issues due to thermal stress (black or blue hulls ... Niagara, etc.) in the past but modern knowledge and practices have eliminated that.
The only downsides is that the 'skin' is subject to impact damage and must remain intact to prevent water intrusion, and if breached must be remedied 'almost immediately' ... and this doesnt in anyway 'favor' the use of structural foams over balsa, etc.
So, when deciding if the advantages of a composite hull are appropriate, it pays to also investigate whether the builder uses 'up to date - modern' methods of non-stop 'continuous layup' or the far less desirable 'time-interrupted' techniques - ie. where everyone stops what they are doing at 5PM and then restart in the next morning. The 'start-stop-start-again methods result in discontinuous bonding between the various layers of the composite structure and thus will have a higher probability or vulnerability of 'delamination' issues later on (.... and BTW this is also true for 'solid' construction). To me, The downside of cored composites is that impacts that crush the core often result in delamination of the core from the 'skin' and need to be repaired because the structure now has 'lost strength' due to the 'structural disconnect of the core'.
All my racing/sport boats are/have been totally balsa or foam cored ... the entire hull. For 'cruising', I prefer and have 'solid' because I dont need to be that continuously 'watchful' to prevent damage. Solid laminates - IMHO - better withstand impact.
One of the issues I have with cored composite hulls is the eventual 'print-through' (bumps) of the resin rich 'cuts' in the balsa showing through the gelcoat after many years of service ... a thicker layer of FRG matting will tend to prevent this; a mostly 'cosmetic' issue.
BTW - Painting a white cored hull to a dark color will greatly accelerate this 'post curing' and will/may add undue thermal stress; but, this can also happen to a solid hull where the structural 'roving' layer also prints through over time and especially when the color was later changed from white to 'dark'. So, if the eventual 'cosmetics' are important absolutely look for 'old' boats from any particular boat builder and see how the 'print-through' is showing or not.
Thats my experience and Im sticking to it. For any 'new' boat as a sailor who favors 'performance', I'd probably favor a totally cored hull because 'weight' (other than the keel) adds absolutely nothing to a sailboat. :)
Ross
Jun 15, 2004
14,693
There is a delicate balance between technically strong enough and rugged enough to prevent skin damage. If you make the laminate too thick you lose the weight reduction benefit of the continous beam construction. Make it too thin and you keep punching holes in it with dropped tools.
Boats that were built in the 70s & 80s in Whitby Ontario, Canada used balsa wood to core and to hire an Australian to replace it w/ Paulownia would be cost prohibitive for me without acquiring a second job. but thanks for the great idea.:)
544
Bristol 43.3 Perth Amboy
Always plus and minus factors
The rationale for cored hulls was to increase or maintain strength while decreasing weight. The total construct is stronger than the individual parts. The old C+Cs were pioneers in this and had a very good reputation for building a solid high quality hull. The modern C+C company has had some issues with quality control as told by a recent article in the Boat US magazine and on this and other forums.
Once delamination has occurred, there are major issues in terms of structural strength. Repairs can be very costly or impossible. The article in Boat US describes one owners tale of woe with a hull with massive delamination. I've done fiberglass repairs on uncored hulls and it is a very straight forward process. Coring makes it much more complex.
My Flying Scot has a partially cored hull. Delamination makes the hulls more flexible, slower and worth less on the resale market.
I'd be very concerned buying an older used cored hull and would definitely get a thorough survey. If I wanted a lightweight racer, I'd go cored all the way.
Apr 15, 2009
302
C&C 30 Annapolis
Just about any vessel in the size range you're looking at will be cored in some areas. Balsa is the most common due to weight, flexibility and resin bonding qualities. Foam is another good choice. Both have their strengths and weaknesses. I'm guessing that the Whitby is cored on the deck and cabin top but not in the hull. The big danger of coring the hull below the water line is impact damage allowing water intrusion so full hull coring mostly seen on racing boats. I'm pretty sure your Beneteau 321 has a balsa cored deck and cabin top. In any event, a good surveyor will take moisture readings and do percussion testing to see if you have any major water intrusion or de-lamination issues. If you're looking at a boat in this age range don't be surprised to find some areas with elevated moisture. Whitby generally did good work so I would expect to find much fewer age and material related issues than you would on a similar vintage Far East built boat.
Fed up w/ personal attacks I'm done with SBO
There is another issue with cored hulls. The interior structure of liner/furniture/cabinetry is bonded to the hull to form a stiffening grid. With cored hulls, the attachment is only to the inner fiberglass skin. Normal sailing stresses impart forces in sheer between the inner and outer hull skins with the core material between trying to hold it all together. Add a little water incursion due to whatever (impact damage, improperly installed thruhulls, etc.) and you could have a real problem on your hands.
Note: Columbia and Coronado hulls of the early 70's (how far before or after that time I don't know) were ALL cored with balsa (also laid up with resin rich chopper guns). Installing a thruhull after manufacture involves coring out the inner skin and balsa to a diameter of 6", filling the void with chopped fiberglass strand and resin flush to the inner skin, then laminating over the whole business with at least two layers of 3 oz. mat and 24 oz. woven roving overlapping the cored area by 4" all around. Only then can you cut the hole for the thruhull.
This process prevented crushing the core material when tightening the thruhull and eliminated water incursion as a result.
Ross
Jun 15, 2004
14,693
This is even more true with foam core but foam cores(Airex and Corecell) are more shear resistant than balsa.
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
I bought a 1986 P36-2... great boat and everything we were looking for except the fact that the p/o's never paid any mind to the stanchions, on deck sail track and other deck fittings. As a result the boat had severely wet decks. I got a real good price on the boat as a result and paid $7,000 to have the decks recored using NidaCor instead of balsa. Replaced from the cockpit to the foredeck...about 27+/- feet on each side So far very happy with the structural part of the job. The deck re-nonskid has a few issues but still looks real good.
In the end I have a boat with new decks and accounting for the cost to recore still paid less at the time for the same boat with no wet deck issues.... For my wife and I a good choice....
Greg
Jun 9, 2008
1,860
- -- -Bayfield
Balsa core
Early balsa core laminations were prone to failure, but as fiberglass construction improved, it was determined that successful core lamination processes should include vacuum bagging. Boats that are not vacuum bagged are more prone to delamination. As long as moisture does not permeate into the core material, then failure is rare. It is when a manufacture skips a step and fails to properly seal water coming in from the outside or when deck hardware or hull hardware is installed and not properly caulked to keep the area dry that makes for moisture problems in the lamination. It should be noted that end grain balsa is used and not long grain. There are a number of core materials, but balsa is used because it is very strong and light and more inexpensive to use than other materials, generally speaking.
Many years ago I wrote an article about Everett Pearson and his contributions to fiberglass composites and it covers the use of end grain balsa. It might be more info than you want to read, but it does give an insight to the development of fiberglass technology. I will paste it below:
Everett Pearson/TPI
Everett Pearson, president of Tillotson-Pearson (T.P.I.., Inc.), of Newport, RI, is definitely on the leading edge of fiberglass technology. Four decades of his use of innovative construction techniques and materials has earned him a reputation for leadership. His achievements literally span the evolution of fiberglass construction. He has built close to 10,000 fiberglass boats from 13 to 64 feet in length. TPI is one of the largest builders of fiberglass boats over 20 feet in the world (if not the largest).
He was first exposed to plastic resins reinforces with glass fibers (called fiberglass or FRP) in the 1950's when he was in the Navy. Intrigued, he and his cousin Clint used it to build a dinghy in their garage. They later displayed it in the 1st National Boat Show in New York City in 1957. The public interest was tremendous and encouraged them to form Pearson Yachts. In the first year they built some dinghies, a 22-foot outboard cruiser and a 14-foot sailing catamaran they called the Tiger Cat. They continued to learn as they went.
In 1958 they purchased a design from Carl Alberg of a 28-foot sloop and named it the Triton. They built a mold and produced hull #1, which they displayed in the 1959 National Boat Show. The Pearson Triton was the first family cruising sailboat made affordable by the use of FRP. Again, the demand was incredible and in 1964, after an expansion period of constructing Tritons and other designs, the cousins sold their company to Grumman. Clint moved on to other things, but Everett stayed on as general manager and the company flourished. They developed new models, set up the testing of various materials and quality control methods to assure that they had the latest in, not only FRP, but also rigging, hardware and sails for all of their boats.
During the Triton project, Everett developed the use of balsa planks sandwiched between glass and resin to stiffen the broader expanses of deck without adding weight. Cored decks became a standard on all Pearson boats.
Since the early 50's balsa was supplied by the Balsa Equator Lumber Company which was later renamed the Baltek Corp. When the problem of migrating moisture (mostly due from the boring of holes into the laminates to mount the hardware, etc.) were realized, Everett consulted with Baltek engineers and they developed the use of end-grain sheets where moisture could not migrate across the grain. It was introduced into the marketplace in 1964.
Later, in 1981, Everett personally proved that the water does not migrate across the grain in a properly laminated end-grain balsa core laminate. He took a 2' square panel, consistent with a hull section of a TPI 44-foot sailboat and sunk it in Naragansett Bay for 3 years. The grain was exposed on the four sides and four holes (2" and 4") were drilled through the middle of the plank. After 3 years they found no water penetration more than 4 mils into the core and no rot on the interior. Inside the balsa wood was clear, white and dry.
Wishing to be on his own, Pearson left Grumman in 1966 and purchased an FRP molding company in partnership with Neil Tillotson. They reorganized it into TPI, Inc. and located in Warren, RI just north of Newport. Everett then took FRP technology into a wide range of product areas, each with differing and specialized requirements. Besides marine products, they developed torpedoes, cooling towers, fan blades, tanks, plating facilities and lighting poles. In the marine area, he built a number of 58' Alden Boothbay Challengers, as well as a host of smaller boats with Baltek core in the hulls and decks.
Elsewhere, in the aircraft and aerospace field, various systems for increasing the strength of core laminations were finding their way into the boating industry. Methods such as vacuum bagging became necessary to assure a good bond across core laminations. Baltek, after an extensive R&D program introduced a new core product, called AL-600, which had a revolutionary surface treatment designed for high-tech applications of vacuum bagging and other methods of sandwich lay-up. AL-600 was the result of a chemical breakthrough in coatings technology. This coating treatment was essential in providing a superbly strengthened bond between the core and laminates. It also greatly reduced the amount of resin used which reduced costs.
On another front, an FRP distributor, Bill Seeman, was developing a low-cost, vaccum-assisted resin transfer molding process of fabricating high-performance FRP composites. He called this new process "SCRIMP" (for Seeman Composite Resin Infusion Molding Process). After a few years of the development and application of this process with prototype structures for Carderock Division of the U.S. Naval Surface Warfare Center, the Navy asked Seeman to build balsa-cored deck panels. At the time Seeman planned to use AL-600, but Baltek, with the desire to improve still further, had developed a second generation pre-coated balsa. The new AL-600/10 incorporated a new coating that was a third the cost and more compatible with current resins including ortho- and isopthalic-polyester, vinylester and epoxy systems. It proved to be more user friendly, saved both material and labor costs on all levels of sandwich construction, increased durability and consistency within the laminates and also reduced volatile organic compound (VOC) emissions in the work place. It was more tolerant to variations and longer gel times as well as changes in temperature, humidity and atmospheric pressure. It proved to be essential to the SCRIMP process. All vessel construction of Navy testing were positive and the results were publically released. It summed up "......this technology is now ready for accelerated development and application to composite boats and craft and to secondary structures of Naval combatants and other ships".
So, towards the end of 1992, the same year that Baltek AL-600/10 was introduced and extensive balsa-cored Navy testing took place, Seeman, TPI and Hardcore Composites of New Castle, DE joined and formed SCRIMP Systems, LLC. They were ready to promote and license others to use the process.
After acquiring the rights to use the SCRIMP resin infusion system the first SCRIMPed production boats Everett and TPI built were the 13.5-foot Garry Hoyt Expo Solar Sailer and then the 64-foot and 56-foot Sundeer ocean passage makers and world cruisers. All used the AL-600/10 core. But, let's back up and reveal another progression in Everett's career.
Back in 1977, designer Rod Johnstone and his brother Bob, approached Everett Pearson with a request to build the J/24. The prototype had already been built in Rod's garage. The idea was for TPI to build it and the Johnstones would market it. The deal was signed, but only after Everett's influence to use Baltek end-grained core instead of the originally planned foam core. From that point on, history was in the making and it was a turning point for both parties. The J/24 became the world's second largest one-design keel boat class, second on the to the International Star Class boat, which were first built in the early 1900's. Rod Johnstone continued to design popular keel boat designs from 22 feet to 44 feet. All were cored hulls and decks with hand-laid Baltek balsa and it has become a solid relationship between TPI and J/Boats. THIS IS NO LONGER TRUE. TPI NO LONGER BUILDS J/BOATS , FYI.
The development of Johnstone's unique designs combined with Everett's high-tech production materials and methods are astounding. J/Boats have made a shift from their previous emphasis of racing thoroughbreds to fast, user-friendly cruising boats that can be sailed with a short-handed crew. The J/Boat designs have repeatedly won Cruising World's Boat of the Year overall winner and Fortune Magazine recently named the TPI-built J/Boats (and the 44 to 54-foot Alden Yachts) among the 100 best American-made products citing their technology, design, reliability and value.
Other boats, not already mentioned, that TPI has built, were the offshore Rampage Sport-Fishing boats, Freedom Yachts, the 37 and 42-foot Jeanneau Lagoon catamarans, as well as the Carl Schumacher-designed Alerion-Express. In addition, TPI built a fleet of 44-foot sail training vessels for the U.S. Naval Academy.
Besides boat building, to name a few, TPI, since the 70's, has designed and built 27 to 56-foot windmill blades for generating electricity, Delta Air Line passenger shuttles, and SwimEx tubs for medical patient rehabilitation and for other applications, such as professional football player's training rooms.
Currently, TPI is working on several new ventures around the world. Besides making fixtures such as fiberglass landscape trees for Disney, TPI is currently testing a new ride designed to attain speeds to 65 mph, where passengers think they are traveling 140 mph. Each unit was Detroit-tested over 50,000 miles. The metal components and welds attached to the fiberglass body failed where the fiberglass withstood fatigue loading and remained solid.
General Motors have been developing an electric test automobile and TPI builds the car body. At 30 mph the cars were smashed into walls. The bodies momentarily collapsed and then bounced back to their original shape staying intact. Everett Pearson is very impressed with GM technology and claims that you will hear much about electric cars in the near future. They are in the process of developing cars that will travel 370 miles at highway speeds between charges. The future might bring hook-up sights at gas stations where yo drive in to get a charge instead of a fuel fill, or have a battery exchange program - and off you go!
For some time now, TPI has produced marine pilings and utility poles up to 75' long. They have tested the FRP pilings with repeated poundings when driven into the marina bottom and they are holding up very well and are expected to outlast conventional materials. Both New York City and the State of California will be using these pilings in new upcoming marina developments.
TPI also has been the largest user of carbon fiber outside of the aeronautics industry.
Everett Pearson continues to do a tremendous amount of R&D to improve the production of SCRIMP boats. TPI has a laboratory used for testing their laminates against other methods of FRP construction and for testing materials. They tank-test various resins and gelcoats by exposing them to different solutions at varying temperatures up to 140 degrees from 350 to 500 hours to determine the best resistance to blister/osmosis abnormalities. It has been determined that one manufacturer of gelcoats outperforms the others and their use of that and vinylester resins enable TPI to offer remarkable blister-prevention warranties on their hulls. They even shoot various calibers of firearms into their Baltek-cored and SCRIMPed laminates to determine whether or not a boat's water integrity would be impaired should it be fired upon. They have determined that bullets do not pass through.
Everett Pearson and TPI are technologically advanced and definitely are riding at the fore-front of boat building technology. They now have become the standard in the eyes of the Environmental Protection Agency because the resin infusion process of putting resins under vacuum solves the VOC problem. The SCRIMP process is very consistent, the results are superior and it complies with the laws of the land. And, according to Everett, the business of composites is in it's infancy.
Author: Bill Hooper
