Steve Viviano
Has anyone ever replaced the aqua lift muffler with a non-Catalina one? The original fiberglass one in my 1983 C-30 is cracked at the bottom and at the inlet pipe and dumps quite a bit of water in the bilge. Rather than try to patch it, I figure I'd replace it. Centek Industries (Vernalift) and Marine Muffler Corp (Naqualift) both make mufflers that will fit (height and hose diameter) and are half the cost of a Catalina replacement. The only problem I see with these are that they hold about half the volume that the stock muffler holds. Should I be worried about water backing up into the engine on shutdown or while cranking?
