Applying gelcoat to the deck
Robin
Ok, so I know this topic has been beaten to death but after a thorough search of the archives and searches through sailnet articles I havent come across anyone who has done what I want to do so I have to ask. I am considering buying one of the "Finish" gelcoat products and applying it to my deck (which as far as I can tell has never been painted and bears the original gelcoat). I was going to use the finish product because it doesnt appear to require a plastic covering and avoidance of air exposure like other gelcoat products. Has anyone done this or anything similar? I want to avoid grinding off the raised nonskid areas if possible. I have a few places on the deck where the gelcoat is worn off down to the fiberglass and I know this needs to be protected, but I think trying to match the color would be a futile attempt and I'd rather just cover the whole thing in one or two coats. Thanks!
Ron Barow
"Computer Match" is not only for online dating.
Robin: Try having the gel-coat computer matched. The boatyard in Stockton, MO uses a company in Stover, MO. to computer match the gel-coat - PAINTS PLUS, 800-472-4551. You send a sample piece of the boat so that they can match the color; they ship you the gel-coat. I used the stuff to patch spider cracks, scratches, etc. in the deck and it worked great. I think the cost was around $50/quart but it was worth it. (A quart goes a long way.) The match was perfect on the white, and the grey non-skid was close enough. The hardest part was finding a piece of the boat to send away - I used a small hatch. (BTW, they send the hatch back, too.) My two cents: 1. Patching a few spots is easier than doing the whole deck. If you must do the whoe deck, have it professionally done. 2. Gel-Coat is really pretty easy to work with once you understand the concept of "put-it-on, sand-it-off; put-it-on, sand-it-off." Remember that the shine comes form sanding and polishing, not from applying it smoothly. There are lots of good resources for "How-TO" gel-coat repair - be sure to check them out. 3. Don't try working when it is too hot and/or very humid. You will just be frustrated by the results. 4. Be sure to spray or brush-on (carefully) the PVA mold release after you have put on the gel-coat patch. It really helps the curing process and just washes off with water when the gel-coat is set. Good Luck. RB
N
NS
nonskid replacement
You should have a look at a product called Durabak before getting into the gelcoat. I think this would do an excellent job if you do the whole deck. See also: http://www.westerly-owners.co.uk/html/body_fulmar_refurbishment.html Durabak will send you a sample if you call them.
Jim WIllis
Non-skid replacement
If you go to the Gelcoat and Plastics forum, you will see that I wrote up a little essay on replacing stippled gelcoat non-skid with the help of Fiberglass Hawaii of Santa Cruz (Mr. COllignon) They also have all the materials that can be sent to you by road. I also wrote one on moulded gelcoat non-skid but not sure whether this is up there. If not I will remind Phil. Hope this is of some help. I have two other articles "in the works" on this subject and I believe sailnet had something about the stick on type of replacement. Thanks Jim W
Tammy
Sailnet article on non-skid
Sue & Larry had an article on applying Treadmaster to the deck of their new boat after removing teak decking.
