Hello, We were out sailing on this fine day on the Chesapeake when I noticed that our Universal diesel was a lil' hard to restart at the end of the day, due to low battery power. I beleive that the batteries are not more than a few years old - two set in parallel wiring. The diesel should have charged them, but they are only reading 12.3 volts without charge, and only 12.8 under power. I believe that they should be charging at more like 13.2 or more volts under power from the alternator charge. I suspect that my original unit may have bad diodes, since it is so easy for them to blow out if the house switch is turned off under power. Anyone replaced their own diodes, and/or where did y'all take your alternator to be rebuilt? A new marine alternator is really expensive, so I hope I can have one rebuilt for less than $200. Although I do recall that the origianl Amp meter can reduce battery capacity greatly due to the inefficiency of the long length of wiring to engine panel gauge.:neutral:
