Finally thought I was near to seeing the light re launching my new to me '81 H36C and then I noticed water from the bilge dripping from one of the two screws that bolt the strut to the hull.
The screws are slotted, countersunk bronze machine screws with a head diameter of about 11/16". I can't reach the nuts (doubled) to check their size and that is part of my problem. (anyone know the size?) Access to the forward one is supposedly through a circular hole in the fiberglass liner just aft of the stuffing box. However the hole is just too small to get my hand though with a reasonable chance of getting it back - and no way to work in there. The other is just aft of the edge of the fiberglass liner below the hatch in the aft locker that gives access (sort of) to the radial wheel on the rudder post. However, this is next to impossible to reach also.
I am thinking of cutting the liner where the previously mentioned access hole is to create a slot of about the same width as the hole that enables me to get my hand in and to reach the aft nuts through. I'm assuming that there is little structural significance to the liner in this area(?).
I've read about people removing/replacing struts to enable propshaft removal without removing their rudders. However I am not sure if any of them were H36C's.
I'm also wondering what my chances are of fixing this leak by removing the bolt, cleaning the hole, filling wiht 4200 and replacing, i.e without removing and replacing the hole strut. Any thoughts?
I'd much appreciate any insight.
Thanks in advance.
Thanks in advance.
