Karl, I sure did. It appears to work fine. Had a nasty squeal when turned on, but after leaving it on all day the squeal is not longer present. I am sure I have a bad cap in the audio amp circuit that needs to be replaced. Probably not holding a charge.
Not hearing KQ2N today. Could be the band shifted.
Sully, still doing some antenna work but I should be good to go in a few days.
