Probably could use a few more pictures. Are the flanges plastic? It seems there is a broken third flange on top? If so, it might be a Cruising Designs (CDI) Reefer I. That would use an internal halyard that cleats of at the furling drum to raise the sail. The Reefer II had a locking mechanism where the boat's jib halyard raised a tool up the spare groove in the extrusion to lock/unlock the mechanism at the top. The tool had an arrow cast into it that indicated which direction to hoist it for raising the sail or dropping it. You have to tie a line to the tool so you can get it and the boat's halyard back down.Anyone know the brand? It is on a friend's Mason 43 boat and there is no documentationView attachment 235912 and no name on the unit.
No evidence it ever had a third flange; the halyard goes down the mast like most RF I am used to. I believe it is cast aluminum. Years ago I worked on a CDI that was on a Caliana 25.Probably could use a few more pictures. Are the flanges plastic? It seems there is a broken third flange on top? If so, it might be a Cruising Designs (CDI) Reefer I. That would use an internal halyard that cleats of at the furling drum to raise the sail. The Reefer II had a locking mechanism where the boat's jib halyard raised a tool up the spare groove in the extrusion to lock/unlock the mechanism at the top. The tool had an arrow cast into it that indicated which direction to hoist it for raising the sail or dropping it. You have to tie a line to the tool so you can get it and the boat's halyard back down.
40 year old Mason 43 from Taiwan. We noticed it has a slight hard spot when turning it. Thinking it is probably bearings but wanted to try and find a manual before going further. I thought it was Profurl at first also.My first guess was a Profurl from the 70’s. They used individual stainless posts outside the drum as line guides. But the tang connection holding the forestay is wrong. Profurl has a sealed bearing beneath the drum.
Fancor also had the stainless post guides, but the guides were in a U shape, solid not individual posts.
Is this a US built boat? What year is it? The style of furler appears to me to be from the 70-80’s.
Is the owner having any issues with the furler or is the question just about identification?
I did not get a picture of it, but it looks similar to a Harken.What does the upper swivel look like?
