Anyone insatll an autohelm on a steering quadrant?
Nov 30, 2008
44
Hunter Legend 375 Sidney BC
I have a 1984 H34 and am wondering if anyone has installed an auto pilot on the steering quadrant?
I want to stay away from the type that goes on the wheel, as I like to remove my wheel when at anchor and docked for more room in the cockpit. If any one can give me some advise as to which system is best and any pictures and dialogue on the installation would very much appreciated.
Cheers Hans
Feb 8, 2014
1,300
Columbia 36 Muskegon
The below deck pilots are stronger, more durable, and out of the weather. But more expensive. I don't think removing the wheel with a wheel pilot is that big a deal. Just loop it over the pulleys. On a lot of boats they have to leave the belt on all the time as it's smaller than the wheel. If you're removing the wheel all the time anyway, that's no longer a problem and you only put the belt on when you need it.
Catalina 320 Dana Point
When I remove the wheel with a wheel pilot I just have to unplug the power at the motor. Below deck pilots are nicer but more expensive, and harder to install.
Oct 26, 2010
2,173
Hunter 40.5 Beaufort, SC
Correct - at least for the Raymarine wheel autopilots, the motor unplugs and the wheel is then easily removed with the autopilot drive assembly (including motor) still attached to the wheel. Not a problem. I don't know the displacement on a Hunter 34 but the newer wheel pilots by Raymarine were not rated for a boat of my size (22,000 lbs). Check the raymarine site and they will tell you the displacement limits for the various autopilots. I am sure that is also correct for the other manufacturers. Don't let the "wheel drive" aspect with regard to removing the wheel. Its a matter of cost and how robust do you need it to be? Are you leisurely cruising, planning offshore sailing where sea state/following seas may challange a wheel pilot, etc. Those should be the determining factors, not the ability to remove the wheel.
Sep 4, 2007
782
Hunter 33.5 Elbow, Saskatchwen, Can.
When I need to remove the wheel for ease of passage the a/p motor has a quick disconnect.
I have a raymarine ST4000 very old but still working. Sorry I don't have any pictures of the helm.
Oct 29, 2005
2,366
I changed my steering wheel to the Lewmar folding type. Just fold it still with the Raymarine Wheel Drive attached to get more walking space.
zeehag
Mar 26, 2009
3,198
my otto pile it is a simrad mounted on quadrant, is electric assist hydraulic, uses minimal electricity and keeps a steady course. withstands a chubasco of 60 plus kts easily and i love it. is as good as another hand on deck.
Hunter 34 Alameda CA
I have the Raymarine X5 on my H34 and remove the wheel all the time. As others have posted, the power simply unplugs right from the back of the motor. Granted a below deck system can handle more weather/wave action than ours. I find it necessary to hand steer as it gets overpowered pretty quickly.
Aug 15, 2013
193
Hunter 35.5 Legend 003 San Carlos, Sonora, Mexico
22,000 lbs for an H34? Really? You must keep a lot of Gin on board. My 1990 35.5 is 13,500, might want to recheck things...
Lander
Hunter 37.5 Santa Barbara CA
On my 1993 Hunter 375 (16,400 displacement, closer to 18K actual) the new EV100 Ray Marine wheel pilot was not strong enough to manage the boat properly. I replaced it with a B&G HLD350 and I used the split version because the clearance is minimal on that boat, mounting the motor and pump in the adjacent locker. The ram itself was mounted to a custom SS arm that was attached to the top of the quadrant and thru bolted to the rudder post. The (Edson?) cast aluminum quadrant is not rated to take the load of an hydraulic ram, and Edson strongly advised against it. It is not the thing you want to fail when you need it.
Oct 26, 2010
2,173
No the 22,000 is for my boat - a Hunter 40.5 (see my pic and signature info). I said I don't know what a Hunter 34 is not that it was 22000. Because of my displacement I upgraded to an internal "rotary drive" that is a sprocket/chain drive inside the binnacle that drives the wheel shaft directly. The Hunter 40.5 was specifically designed for that drive and the mounting bracket was already factory installed inside the binnacle. It made the installation a snap. It eliminates the need for complex linear drive attachements or arrangements and I was leary of putting the linear drive on the cast rudder post quadrant too.
193
Guess i was hoping for a fellow Gin n tonic drinker.... thanks for the clarification. :)
