Brad Williams
Ahoy all,I have a new (to me) Capri 26 -- and I have just several questions.1) The listed dry weight is 5100 lbs or there abouts. But, this is the weight Catalina lists whether or not the boat has a deisel (which mine does). Has anyone put their boat and trailer on the scales?2) Comparing notes on a similar, but slightly newer Capri 26 at the boat storage yare, I see that I have a trailer that is rated for a maximum weight (trailer and boat) of 7000 lbs. This seems light when the other guy's trailer is rated at 9999 lbs. (both are TrailRite) The trailers seem identicle except that his tires and wheels are bigger.....bigger axels also perhaps. When buying new....you don't get your choice of trailers...or do you? Sometime between 1990 and about 1994, did Catalina decide they needed the bigger trailer or what?Thanks.Brad
