Guess it is time for a mechanic though they seem to be in short supply here in the Dallas area where my boat is.
I'm confused. Kenn provided you with the whole engine manual for your diesel. I read it. It says the engine is self bleeding. What is a "mechanic" gonna tell you that the manual hasn't already described?
OK, OK, if it still won't start and you HAVE read the manual, have you tried playing with the bleed screw? My M25 engine requires that the bleed screw be opened for a short period of time with the electric fuel pump ON. The clicking of the fuel pump is rapid, then you slowly close the bleed screw, and the clicking slows down - very evident. If the clicking remains rapid, there's still air in the lines, so do it over again until all the air is out.
The M25XP is essentially the same engine, but is self bleeding.
If this doesn't work for you, then I suggest you go to to the C320 Association website and ask there, or just do a search there on "bleeding" and I'll bet you get an answer almost immediately.
www.Catalina320.com, most likely.
Good luck.
PS IMPORTANT!!! Have you opened up the fuel shutoff valve after you changed the filters???? Believe me, I've forgotten to do that myself, and will actually admit it!
PPS -
http://groups.google.com/group/c320...cf9b4?lnk=gst&q=bleeding+30B#e5cd512ec94cf9b4
This thread talks about a faulty fuel pump, which could be possible in your case.
In addition, how is your fuel plumbed? Many Catalinas, if not all, came from the factory with the fuel pump first after the tank, then to the Racor, then to the engine. What happens is that the tiny filter at the base of the pump gets clogged up. If you have the metal Facet pump, simply remove the bottom of the pump with a ratchet/socket wrench and check that filter. Then, correct the plumbing to: tank, Racor, then fuel pump, then engine.
PPPS - If you have changed the secondary filter (on the engine) you most likely have to open up the screw on the bracket that holds that filter to assure air is completely out of that new filter, because the bleed screw doesn't work for that secondary filter. At least it doesn't on my engine. Try that, too.
PPPPS - Your engine has the what is crazy to me electrical arrangement where the fuel pump only runs when the glow plugs are on or if the oil pressure is "made." This means that having the key switch ON will NOT run the fuel pump. So you either need to hold in the glow plug button or key position to run the pump or you have to rewire the fuel pump to run when you want it to. I've discussed this on our C34 Forum, since the M35 engines in our boats are self bleeding, too, but one of our skippers raised this very question:
http://c34.org/bbs/index.php/topic,5078.30.html
