Anyone gone aloft on H260?
62
Hunter MH 40 Noank, CT
Has anyone gone aloft on their H260? I stepped the mast the other day and then noticed that I screwed up the windex. I figure it might be easier to send someone up with a screwdriver than to drop the mast and re-step it. Will the H260 rig support someone less than 200 lbs up there?
I've got a chair and can do this safely if the rig will support someone.
Thoughts?
Apr 1, 2004
178
Diller-Schwill DS-16 Belle River
Just a thought, if the boat is not totally secured, once it starts to heel, your heeling moment increases to around 3000# just before you climber hits the water.
Jul 29, 2009
5
Catalina Catalina 270 Lake Conroe
We send a guy up on Catalina 25's all the time. I own a H270 and would not be afraid of sending someone up. However, if your not sure, it's not that big of a deal to lower the mast. Use the main to pull him up and the jib halyard for safety.
John
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
I used to go up the mast of my H27 on occasion and I'm 200+ pounds, so I don't think you will have a problem on yours. Just be careful and go slow. Hardest part is getting past the spreaders.
Cheers,
Brad
Jun 1, 2004
243
Hunter 26 Lake Pueblo Colorado
Why not just lower the mast. After all that is one of the advantages of having a trailable boat.
May 25, 2004
958
Hunter 260 Pepin, WI
I would not be afraid of mast failure or boat stability. I just think its easier to drop the mast again on the H260.
I find the windex a useless item and in the past when I got the angle wrong or something it would stay that way until the next time I brought the mast down. That's all season for me.
Aug 11, 2006
1,446
Hunter H260 Traverse City
I agree with Dave: Learn to read your sails and feel the wind; forget the windex. I've replaced several and finally gave up.
Attach a couple of tell tails to the shrouds - that gives you an idea of the wind direction. If you are a racer, the windex is not accurate enough to give you apparent/true wind directions.
Finally, I can lower my mast, put a windex on it and raise it again in about 10 minutes no sweat. With a friend helping even less. Going up adds risk and hassle not necessary.
Not even close.
