Howdy,
Freshwater pump (pic) leaks suddenly. Hasn't been used since December - full of antifreeze.
Now it leaks from the bottom; I think from the center screw on the bottom plate. Only leaks when pressurized. Drools about 2-3 ounces a minute. I tightened the in\output connections - no leaks there. Also tightened the screws. Still leaks.
I now suspect the gasket under the bottom plate. Jabsco calls it a "Pulsation Dampener" (pic).
Anyone had this issue with this pump? I would hate to play hit-and-miss with parts repleacement, if this issue sounds familiar to anyone. What about gasket sealer instead of a new part?
This is the stock pump that Bristol installed 27 years ago. Amazingly, the identical model is still available from Jabsco, but it's $375, so I'm hoping to get another 27 years out of this one
