hmmmmm
I disagree with your thought process on two counts. If what you say is true, then why does the water push backwards when I go forward on my boat? By your thinking, I should be going sdrawkcab. On another plane, the motor would be reversable, so your statement is meaningless. If in fact the boat pulled toward the pushing water, then you simply use the system in reverse.
