Anybody Tow A 13' Boston Whaler?
Rick D
Jun 14, 2008
7,204
So, I am buying a 13' Boston Whaler (used) with a 40 HP OB. My purpose in buying it was to have something to recreationally use in the harbor. My wife evidently has other intentions and wants us to take it the 35 miles to Catalina for use there. I don't have a problem towing it, but am wondering the speed penalty. I figure a knot under power and probably the same with 14-20 knots of wind under sail. It weighs about 1,000 pounds wet with engine. Any experience out there?
capta
Jun 4, 2009
5,078
I would guess you are underestimating the drag by a factor of two or more. Let us know what speed you actually do manage to get towing that monstrosity.
Likes: Rick D
Rick D
Jun 14, 2008
7,204
Yea, I know, huh? I did talk to a guy with a Catalina 42 who towed one who said it cost him about a knot. (I found an old post on the same question by someone else a few years ago). I guess I'll find out! I'll report when I figure it out. Happy wife, happy life...
Rick D
Jun 14, 2008
7,204
snickering* Have the wife drive it over while you sail over...:hijack:
Actually, it's done. 13' is a tad small for that though, but people do it. That would not include me for openers! :yikes:
Of course, there is always the stuff you didn't think through, like where to store the trailer, putting a hitch on the SUV, bottom painting, and whatever else I forgot.
Aug 22, 2017
1,609
Hunter 26.5 West Palm Beach
Back in the 1980's I spent several weeks cruising up & down the east coast in a 42' Beneteau, dragging a 13' whaler behind it. Yes there was a little speed penalty, but it was well worth it. The speed difference was not that great. The real issue comes up when you have a following sea & the whaler wants to ride up & plow into your stern.
Likes: Rick D
Oct 1, 2007
1,865
You need a strong, custom tow bridle, strong points for attachment on the Whaler, and a big, strong cleat to belay the tow line on your big boat. Still a scary idea to tow a large boat 35 miles in open water. I think the speed penalty is the least of the challenges...
Likes: Rick D
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
Rick
My late friend Robert towed his 13 footer behind a Hunter 43, which is similar to ours. I think he had a 40 or 50 on it. Well needless to say, he could only get about 4 knots and change out of her under tow. And that was with a bridle. Will have to see. Good news is your legal on the dock over at TH although you better get a long long long long painter!
Cheers mate.
I may need a one night in August for nephew and fiance that we are going to do the crossing out of DP on a saturday. Will be in touch.
Likes: Rick D
Jun 2, 2004
3,658
We use an older 13" Whaler as one of our coach boats in our junior program. It tows pretty well behind a power boat but I can't help with how it'll do behind your Hunter. We use to take one out and surf the waves coming into Hickam Harbor, long time ago.
Couple of other things I can tell you:
The Whaler is the first boat grabbed out of the four we have. it handles the best and is the most comfortable.
If it is a four stroke motor on the 15' transom model you are going to ship water over the transom.
Don't use the cleats on the first transom if you have the model with two transoms.
If you are going to tow it using the bow eye reinforce it with the biggest thickest fender washer you can find.
I am sure ours is way more than 1,000# it is a 1965 model and I am sure fairly water logged.
We have a 4 stroke 25HP Yamaha on ours and has plenty of power. We raised the transom up to 20" and put the gas tank at the bow them moved the seats forward to the tank to help with the weight distribution from the heavier 4 stroke motor.
Likes: Rick D
Dec 29, 2008
806
Treworgy 65' LOA Custom Steel Pilothouse Staysail Ketch St. Croix, Virgin Islands
A friend here bought one on St. Thomas and towed it back down here to St. Croix. After the trip he dubbed it the "Red Oktober", because it kept diving, ramming into the transom, and basically shredding itself. The bow of the Whaler, and the transom of the Jeanneau 37, suffered significant damage. Just something to think about. Now, that was probably in 4-6' seas, which are pretty common here between STT and STX. Might have been less of an issue if he'd had a longer painter on it. I'm not sure how far behind the boat it was, but in those seas it might hot have made any difference!
Likes: Rick D
Mar 12, 2008
557
Jeanneau 49 DS San Pedro, CA
With a Boston Whaler back in Cat Harbor, you’re going to be mistaken for a resident live aboard back there!
Likes: Rick D
Rick D
Jun 14, 2008
7,204
For sure, huh. Step one will be seeing how she tows! If it's hauling a sea anchor, the little one goes...
Aug 22, 2017
1,609
In following seas, we picked the feistiest teenager on board & sent him out to drive the whaler next to the mother ship until conditions improved or we changed tack.
Likes: Rick D
Jan 30, 2020
2
Catalina Capri 37 San Diego
Interesting, several contributors have read much about towing. One, painters are only used to tow in protected waters. Two, a stout towline, in this case 1/3 to 5/8 inch would suffice, and the length should be longer than a wavelength to prevent the towed boat from surfing into the towing boats transom in a following sea. Open ocean wavelengths are too long to make this practical so a small drogue to keep the towed boat from surging is necessary. And finally, towing a small boat over 5 knots in any situation is begging for trouble in the form of capsizing, bow nosing under a wave, damage to towed or towing boat hardware and chafing of the towline. Towing a boat that is a third the size of the towing sailboat is not recommended die to compromised maneuverability keep the towed vessel size at 25% or less, hence dingies tend to be 8’ to 10’ so your typical 30’ to 45’ sailboat can tow and maintain good steering. With ribs you see a lot of ill-considered tows about, but just because one can do so doesn’t mean it’s good seamanship.
Sep 7, 2022
70
Captiva Yachts Sanibel 18 Lake Wylie
Probably should set a crew member just to watch the tow as well, I'd suggest.
