Anybody replace their CNG tank with LPG?
weinie
Sep 6, 2010
1,297
I was thinking about replacing my CNG system with LPG.
Catalina Direct offers the 2 1/2 gallon tank and locker.
Will that fit in the aft lazerette without modification?
Also, since gas drainage at the bottom of the locker is needed, what is the best way to vent it through the hull? I was concerned that another thru hull fitting so low to the waterline might also end up an entry point for sea water!
For boats with existing LPG systems, where is the thru hull located?
If anyone has any hints on the installation, I would really appreciate it!
If you end up doing this, you also will need to modify the burners. Find the model # of your stove inside the lid, and call Seaward, they'll help you out.
