Appears my original 2003 MarineAirr (now Dometic) heat pump has bit the dust. I had some intermittent sticking of the reversing valve over the winter and we’ve used the boat heavy compared to most with 1209 days on board since new in March 2003. We run 100% while onboard either via dock power or generator, ran it continuously while on a winter cruise to Florida for 6 months in 2013-14 and for the last 4 years I have wintered it at my hometown marina where I left it on power all winter and kept it heated with the unit.
I’m going to replace the unit and the seawater pump. Size of the ECD 16000 BTUH unit is really close but the blower and compressor look like they have swapped ends so the unit will turn 180 degrees from original. How has this been dealt with a replacement and if so, how did you deal with the ducts?
Thanks.
Thanks.
