Anybody recognise this Yanmar?
druid
Apr 22, 2009
837
Ontario 32 Pender Harbour
I'm about to buy an 1976 Ontario 32, but I can't identify the engine. It's an OLD Yanmar (probably the original), 2cyl, RWC. Looks like it pre-dates the 2GM series. Anybody know the model?
She runs really well - starts right up, good compression, runs smoothly, no smoke. So I'll probably not replace it, at least not for a few years. But I need to know the model...
druid
Jun 1, 2004
412
Catalina 22 Victoria BC
druid
It looks similar to my 2QM15 (which is absolutely from 1978) particularly the fuel filter, the routing of the cooling hose on the top and the location of the zinc. However, the belt configuration is completely different and I don't have a cover over the alternator belt nor any provisions for one. Also different is the the location of the water pump. My pump is on the left, at the bottom in the most inconvenient spot possible. I actually have to remove the pump to change the impeller. Not a quick task.
I suggest it's not the original engine form 1976 as it has design improvements for safety (belt guard) and for convenience (water pump location for changing impellers)
My two cents worth.
Apr 22, 2011
939
Hunter 27 Pecan Grove, Oriental, NC
The cover appears to be for an external timing chain, not the alternator belt.
There should be a metal plate somewhere on the engine with name and specs. It could be behind the chain cover.
Apr 27, 2010
968
Beneteau 352 Hull #276 Ontario
Have to agree with David
The 2QM15 was manufactured from 1975-1980
The 2QM20 was manuafactured from 1975 -1980. This one had many versions.
Good luck
Jun 1, 2004
412
On my engine, the plate is on the lower left side of the block (when facing the engine). Mine is near impossible to read so I gave it a cleaning once when I managed to get reasonable access and it confirmed the specs. Sadly, I wish it said 3YM20 instead...
Just ran across a picture of a 2QM20 taken from the top and it had the same belt cover as yours. Interestingly it had two yellow oil fill locations on the top of the valve cover whereas my 2QM15 has only one.
I'm very confident you have a 2QM20: have a look at the attached photo.
95
Watkins 27 Port Charlotte, FL
The cover is over a crank starter chain. My 1977 model YSB8 has a similar crank start shaft on a chain drive that lets me crank start the engine if I have to.
druid
Apr 22, 2009
837
Yes, David, that sure looks like it! The cover is over a chain, not a belt, and it'd for the hand crank. The cover looks like it's been sawed off half-way - almost looks like the water pump was moved and the cover had to be cut away to accommodate.
I'll look for the label next time I'm at the boat. Thanks folks!
druid
Jun 1, 2004
412
druid
From your original picture, I think it was sawed off to accommodate the aftermarket water pump.
zeehag
Mar 26, 2009
3,198
looks like my 2qm20h--came with my ericson--i bought her a 600 hour overhaul when i bought her--runs awesome well...
druid
Apr 22, 2009
837
Anybody have the specs for this engine? The Yanmar site has the owners manual, but it doesn't have hp, max rpm, idle rpm, weight, etc.
druid
zeehag
Mar 26, 2009
3,198
my ericson's 2 qm20h is 20 hp.
i had a tachometer placed and was showing 800 rpm at idle--- and cruises most comfortably at 2200 rpm....dont know the weight...
pacwest marine and industrial in san diego, shelter island would know the rest....i dont have the telephone number anymore, but he is also online....elias is the name of owner of the company. he is the distributor/dealer in sd.
