Anybody bought a Marine Air Controller board?
Jim Logan
I finally got enough time on a weekend to definitively determine the problem with my marine air system is the controller board - I'm waiting until Monday to call the distibutor - the system is 8 years old, so I'm not too eager to put much money into it - has anyone replaced the system board (the part with the triac and chips on it that controls the fan and compressor and water pump) recently? wondering about the price - anybody got any wisdom or tips on this - it seems a fairly simple controller board as those things go, so I might try repair if it is too expensive to replace. Thoughts?
O
O_salt
What model digital control or what is the part number on the printed circut board you have. The controls from Marine Air where not always upward compatiable. I might have the board you are looking for if I know the display you have. O_salt
Jim Logan
Its the Passport digital control
Its the passport digital control - the circuit board has the words " cabin mate " followed by a number - I left the board with the local distributor over the weekend so he could look it up on Monday, so I can't give you the exact number - the unit is a 16k btu, cool/reverse heat, about 7-8 years old. I am concerned it was manufactured during the time Marine air was changing from a Passport I to a Passport II design, but having looked at their web site, its hard to tell the difference - I think it is a passport 1. Compressor and water pump run when powered independently, no power from line out on board when their should be.
O
O_salt
Digital Control
I looked at the control I had, and it is before the Passport I, called the ECU. I don't think this will help you. Let me know if you can't find a replacement, I know of a real good Distributor / Dealer in my area. O_salt
Jim Logan
For O_Salt - thanks
That ECU controller is a manual control for the Marine Air Systems unit - It might actually work, it just has a basic on/off switch, Heat/Cold selector and thermostat like a household central air unit - the Passport system has several features, such as humidity control that I would like to retain, but from what I understand, the Passport system is just an extra cost option on the Marine Air systems, the ECU type unit will work if you want "manual" control. Thanks for the help
