G
Gaspare
Over the weekend I attemped to remove the prop. No idea when the last time it was off. I cleaned things up quite a bit, was able to get the two nuts off using lots of WD-40 and a little heat. The prop is on tight. I used a home made prop puller but it still won't budge. Prop and shaft are bronze. Any ideas?
