Was flushing out the water heater yesterday and got a little confused about the plumbing configuration that the PO had set up. When I bought the boat, he showed me most of the modifications (except for this one) and they were all done to make life easier when at the dock, winterizing or cleaning the systems out.
This modification is a piece of hose between the cold water inlet and the hot water outlet hoses and the hose has a valve in the middle. I'm not sure if this is normal or something that was added but it is not in the Seaward manual.
My assumption is that it allows you to shut off the incoming cold water just before it enters the heater and use the pressure pump to empty the water heater tank without running the pump dry. Am I wrong about this? Can anyone tell me what this may be for if I am so I can use it properly?
