You need the following information.
1. Calculation or estimate of material ingested measured in micro, Nano , or pico curies., Or grams,
2. You need to sample any remaining source material on the penetrating implement, which also has to be prepared and weighed., It should be characterized as pc/g or some such.
3. Urine and stools properly collected for 3 days,
4. A certified rad lab, using the correct equipment.
Then you can start calculating dose. Otherwise. They are just guessing based on source info. Ingested radiation is measured in quantities of material, along with the clearance time as measured for you. Dose rate means nothing... It is still in your system.
A tech with a 2 year degree is unlikely to be able to calculate your total dose you receive.
2
2
