C Crazy Dave Condon . Jun 8, 2004 10,536 -na -NA Anywhere USA May 20, 2022 #2 Mfg. & model boat, mfg of hatch and dimensions please
kloudie1 . Nov 6, 2006 10,221 Hunter 34 Mandeville Louisiana May 20, 2022 #3 The Hatchmaster.com folks have a great history. If you are a diy guy, you can get the lens custom cut and install it yourself.
Ralph Johnstone . Jan 4, 2006 7,687 Hunter 310 West Vancouver, B.C. May 20, 2022 #4 kloudie1 said: If you are a diy guy, you can get the lens custom cut and install it yourself. Click to expand That same DIY can also use a router template bit to fabricate a new lens +/- 0.001" from 3/8' acrylic for about $30.00. Likes: kloudie1
K KGarvey . Jun 5, 2018 53 Beneteau 35S5 Buffalo, NY May 20, 2022 #5 The boat is a 1989 Beneteau 35S5 Dimensions gasket to gasket 15 &1/8" wide 20 &1/4" depth
P pipedream . Jul 18, 2015 74 South P10 Pugetopolis May 20, 2022 #6 Just finished mine yesterday. I had the basic measurements cut, then put the radius corners in with a router. Installed with dow 795. Attachments 20220517_163409.jpg 590.6 KB Views: 113 20220519_175506.jpg 547.1 KB Views: 112
