Jack, Moeller makes a 6 gallon poly fuel tank that fits against the inside transom. It may work for you if it fits. If not, check out the fuel compartment on a 2002 McGregor 26 for ideas on how to build one for your boat.Joe
The latest issue of Good Old Boat has a great article about adding a storage locker under your cockpit seat. Should be able to modify their setup for your boat. It seems like it would be easier to do than you would first think.
Thanks a ton!$8Dodge, which issue/what month is that article in?Joe, I am going to measure the space and see if it will fit, I had seen those too.Thanks again!Jack
I think it's the current issue shown on their website.http://www.goodoldboat.com/I'll try to double-check when I get home. It's definitely one of the last 2 issues because I just subscribed a couple months ago and have only received 2 issues so far.
