any info on replacing keel bolts on 43 beneteau?
Jconn
Feb 3, 2013
2
Beneteau 43 Palm coast
We are purchasing a 43 ft beneteau and surveyor states we need to replace the keep bolts.
Has anyone gone thru this process? Can you offer any advice on what we need to discuss with the boat yard before the procedure? We are getting an excellent price on the vessel and are expecting about $7000 cost for replacement based on one estimate so far.
Will appreciate any and all response.
Jan 4, 2006
7,611
I think we'd need a lot more info here such as age, previous grounding(s), etc. to see the reason for replacing the keel bolts before commenting.
This is not a regular maintenance item.
Jconn
Feb 3, 2013
2
Boat is 1986... Bolts are rusted and surveyor suggests they need to be replaced.
CHM
Oct 30, 2011
70
Beneteau 432 Merritt Island
Get more estimates. That sound high. Order replacements from Beneteau in South Carolina. About $125 shipped. Shop around for labor amd to see what is involved. Worst case scenario is hauling boat and dropping keel.
May 25, 2012
46
Beneteau B393 Norfolk
I would hope you are getting a good price for it! I'd drop my offer 7k! But shop around for replacement costs.
Jun 7, 2011
83
Beneteau Oceanis 361 Marmong Cove, Australia
What you need to discuss with the boat yard as to why the cost, what are you getting for your money and what service he is going to supply. Seriously as already discussed, I think the yard is having a lend of you and you need to get several quotes. However if your not telling us the whole story there may be more work to be done to the keel and price may be justifiable...? :confused:
Gunni
Mar 16, 2010
5,937
Keel bolts can be removed/replaced one at a time. It is not a $7k job.
Jul 23, 2012
2
Beneteau 373 Kingston
Getting at the keel boats in ours requires removing quite a few of the interior furnishings and systems. If this has to be done, and that is included in the quote, I can see the cost adding up quickly.
Dec 31, 2012
12
Beneteau Oceanis 430 Penang, Malaysia
Jconn,
the 43feet Beneteu, is it one of the early Oceanis models? If so it's propably very similar to my 1989 Oceanis 430. I will change my keel bolts very soon as the bolt heads appear rusty.
Be sure to know what material your Beneteau keel is made of:
· Cast Iron keel use galvanized bolts - There are threaded sockets cast into the keel.
· Lead keels use stainless steel nuts - There are threaded rods cast into the keel.
After having done some research I estimate this to be a fairly routine DIY job, with my boat anyway, as I don't have leaks, so I don't expect having to drop the keel. Unless I will have complications with detaching the bolts; check out the attached pdf-document "Keel Bolt Information" sent to me by Beneteau spare parts department USA.
Also, for the sake of education, check out the links below, and do some more searches on the forums. This will all help you to make an educated decision on your particular situation:
Here are some related links:
http://www.beneteau235.com/keel_bolts.htm
http://www.cruisersforum.com/forums/f55/keel-bolts-8119.html
http://features.boats.com/boat-content/2012/06/how-to-replace-keel-bolts/
http://www.ybw.com/forums/showthread.php?224192-Beneteau-Oceanis-37-keel-leak/page2
http://www.sailnet.com/forums/boat-review-purchase-forum/67272-rusty-keel-bolts-how-bad-2.html
http://www.sailnet.com/forums/gear-maintenance/93285-grid-system-repair-3.html
Best regards,
Erik
