Any help please with 1984 H34 mast/boom specs?
4
Hunter 34 Christiansted, St. Croix
Hello Fellow Sailors,
Gordon here. In an effort to re-rig my H34 after a dismasting I am in need of a few measurements that I am unable to obtain. If any of you H34 owners could spare a few minutes measuring on your own boat I would owe you many thanks. This is what I need please-
Length of H34 boom
Speader lengths and widths (all the same??)
Exit blocks and angle on H34 masts
How many exit plates on the mast
Type of upper shroud tangs and distance from mast head
Thanks again:) Gordon-St.Croix
Oct 14, 2005
2,191
Gordon...
While I have what passes for an owner's manual for my H34, I don't recall any specific dimensionals being given in it that could be used for re-rigging.
I would suggest that you get in touch with Hunter's technical support to see if they have any specification call-outs that will provide you with that information.
Also check on this site's H34 model listing under the Boat Info tab at the top of the page as that should lead you to some of the specs you seek.
Keep in mind that these boats were rigged with a B&R rig that was set up (tuned) off the boat with the mast then being set in place and trued up on centerline and perpendicular in the boat.
Given your location you have a major task ahead of you in trying to find a replacement. Over 1,200 of this model were made so you might get lucky and find a salvaged rig.
Good Luck!
Nov 6, 2006
10,206
My rig is up so I can't measure it, Gordon.. sorry.. I believe that Dan is right on..
Dec 2, 1999
15,184
Have you considered contacting Rig-rite in R.I.? You may also consider contacting Seco South in Fl.
Sep 26, 2008
22
pearson-vanguard 32.8 hull#60 irvington va.
you can mesure the sails that will give you the smallest lenights that the mast and boom should be. to know the itx and the ity would be nice.i have sent many a riggs to st.croix.
Dec 2, 1999
15,184
Gordon:
There is a mast for sale in the Gear ads. It would be interesting to know if this rig from a 33.5 would work on a 34.
