Any Feed back on Cable Clam through deck fitting????
jfmid
Jan 31, 2010
152
Oday 27 LE Manahawkin, NJ
Hello All,
Before I go and cut another hole in the top of the deck I wanted to know if this device works well. I looked it up on a search of the forums but could only find one person who used it. He said it works well but that was years ago. Just wondering what the general opinion was.
BLUE SEA SYSTEMS CableClam Waterproof Through-Deck Fittings
This is for a VHF where the end does not have a pg259 on it yet.
Thanks
Superb performance on our C25 from 1987 to when we sold her in 1998. A good bit o'kit, as they say....:)
Also, rtfm...
DannyS
May 27, 2004
933
Beneteau 393 Bayfield, Wi
I've used it and it works great! I bought the largest one they make and used it to run the radar cable, anchor light wire, and loud hailer wire through it. You have to drill through the rubber and slice it so it can accept the wire. I drilled three holes and made three slices so I could run three wires. It worked pretty slick!
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
I agree with the others. But CAUTION: When drilling the hole(s) make sure they are a snug fit. Use a micrometer on the cable and pick a drill of that size or very close to it. That way when you screw down the top cover it will force the rubber very tight to the cable and seal it.
Manny
Oct 5, 2006
983
Hunter 82? 37 Cutter Wherever the wind takes me
Yes, they work well. I used one when I rewired my mast a few years ago, no issues.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
yes they are a very good divice for running wires through the deck and or cockpit floor ... you do need to be very percise on drilling the hole and also when you cut the split use a sharp knife not any kind of saw that will remove the material ....i used two of them in march on an allmand 35 and have had no issues with them....a little pricey but then you get what you pay for ...they also make an elongated one as well for multy wire use....good product....
regards
woody
Catalina 30 Mandeville, La.
I'm not familiar with this particular device but I have seen similar devices on non-marine outdoor radio cabinets and such, They are never used on a flat-top surface but instead on the side or bottom. It may be fine but that jumps out at me right away. Obviously, others here are more familiar.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
Been using them for years and they work as advertised. The plastic does deteriorate if out in direct sun for in about 4 years. Chuck
