I put my boat back in the water this year and found that it heels badly on port tack. ie it seems to sail normally on starboard and very sensitive (unstable) on port. I thought maybe the keel was not down but after realizing it was only on port tack I thought about balance issues. the only thing I can think of is I left the boat in the water a couple of winters and did not use it due to work. I took it out completely last year and left it in dry dock. this year it is unstable. if the ballast tank froze and cracked and the water is not retained in the tank could I have a new ballast next to the tank only on the starboard side of the boat? this weight addition would explain the behavior. if that is the case is there fix?
