I got the Rancor from West marine last
November, im not sure what series it is at the moment. Its all plastic with a clear base, pump in the top, spin on steel 10 micron can filter in the middle. Before i added this filter the only filter the engine had was a single can filter on the engine itself, and no water separator. when i get it down here, i plan on adding another filter in an easy to get to point to filter down to 2 micron. Ive seen several setups with vacuum gauges, what are they for?
