Any Catalina 30 MKII owners out there w/leaky chain plates?
9
Jenneau 27 Rented
We are considering purchasing a Catalina 30 and read in a review that many of these have leaky chain plates. The one we are considering purchasing does have leaky chain plates... Any Catalina owners out there with this problem? Is it a disaster? This would be our first boat....
Re: Any Catalina 30 MKII owners out there w/leaky chain plat
Chainplates are a regular maintenance item. They are quite easy to rebed properly.
Jul 19, 2011
9
Jenneau 27 Rented
The seller just caulked the chain plates, he did not rebed them...what are your thoughts on this?
Jan 4, 2006
262
Catalina 36 MKII Buford, Ga.
The proper way to do this is to remove the chain plate to be able to inspect the area. If the core is "wet", that would dictate different steps to correct the problem...and depending on the severity. If the core is "dry" and solid, then you would simply clean the area and rebed chain plate.
IF the seller just caulked around the outside of the chain plate...that is not acceptable and not the way to do that maintenance. IF that's what they did, it would be a "red flag" and concern me on how they might have carried out other preventive maintenance procedures.
As you determine what vessel you would like to purchase, you really need to engage a top surveyor in your area to perform that inspection. You should accompany them at the survey and bring a pad of paper and pen to write down a lot of information....a good surveyor will save you lots of heartache (and dollars) and the good ones will teach you a lot if you show a genuine interest to learn.
Very good advice. Bring a camera, too. :)
jrowan
Mar 5, 2011
1,294
There are two types of chainplate situations: ones that have leaked or are leaking, and chainpltes that will leak in the future. Its unavoidable due to the high stress loads they must take from the shrouds / standing rigging. As mentioned above, its all about the maintenence! I and many other sailors have been found guilty of applying caulking as a preventative measure around chainplates where they penetrate the deck. An ounce of prevention....
