A bad paint job...I've already lost two (stolen from me) so I'm a little anxious leaving my 2006 9.9 Honda on the boat for the week... whats the best Anti-theft devices out there?
Best anti-theft device is made by GlockI often worried about my motors(1st a 2.2hp then a merc 4hp) being stolen and for a while installed and uninstalled each use. this got to be a real drag and i started looking at the larger boats to find that they were using a motor lock (availabe at west marine) that slips over the long thumbscrews and has a padlock slip in that shows hardly any of the lock to be hacked at or pried at.
Of course, any anti-theft device will only work if the thief is not determined to have YOUR item, and any battery powered recip. saw will slice through the adjustable motor mounts or even the turnscrews themselves in a few minutes.:cussing:
That works if you can spend your life in the boat. How about a GPS child locator?Best anti-theft device is made by Glock
The downside of these I found is that one tends to forget about it and the lock, which gets hit with water all the time when the engine is in the down position, quickly freezes up and then YOU have to play thief to cut it off yourself! I went to chain, then plastic covered wire with Nicro press loops at the ends. No matter what you do, a well organized and equipped thief is gonna cut through almost anything that is of reasonable weight and heft without being obvious overkill. The weak link in the chain (pardon the pun) is the hasp of the lock, which bolt cutters will make into butter in a few seconds. Almost a given: grin & bear it, that's what insurance is for, but doesn't make any of us feel any better. There is simply no way to stop it, other than stopping the entrance of the thieves....started looking at the larger boats to find that they were using a motor lock (available at west marine) that slips over the long thumbscrews and has a padlock slip in that shows hardly any of the lock to be hacked at or pried at.
I can buy a used 9.9 two stroke with good compression for a few hundred dollars. Spend a weeks worth of evenings tearing down and rebuilding and have a motor that starts every time for several years at least. I bought an evinrude electric start long shaft in 1999 and it's still great. I would be pissed but not broke if someone made off with it. I know 4 strokes are more efficient et cetera but $2000 will buy me gas for 15 years.I've already lost two (stolen from me) so I'm a little anxious leaving my 2006 9.9 Honda on the boat for the week... whats the best Anti-theft devices out there?
probably just removing the handles from the clamping bolts would help.
How does one like this one work? (not looking for an answer like "well")
