Last spring I had the bottom of my MAC 25 stripped down, blisters repaired and repainted with three coats of teflon paint. However, the contractor talked me out of having an anti-fouling paint applied, which was a mistake. Although I sail exclusively in fresh water (docked for the season on Oneida Lake in upstate NY), when I pulled the boat out this past fall the bottom needed an intense acid wash to remove the algae from the bottom.
My plan now is to apply an anti-fouling paint myself this coming spring. With that in mind, I'm looking for suggestions on the type of paint I should use (ablative, non-ablative, name brands, etc.)? I keep my boat in a slip from May - October at a marina on a fresh water lake. Ease of application and yearly maintenance is high on my priority list.
Thanks,
Thanks,
