I was running down a 110 VAC electrical issue when I found this wire labeled: "ANT REM MAX 0.1A". It isn't connected to anything. I also note the green wire (a ground?) not connected to anything labeled "ATT". They are behind the power panel in the wire bundle to the stern o the compartment
Anyone know what these wires do and where they might be connected?
The 110 VAC issue: I had no power to the GFI receptacle (the only one in the boat) in the cabinet above the stove or in any other receptacle further forward. No power to the Air Conditioner / Heater. No power was getting from the "outlets" breaker to the GFI receptacle. I was getting power to the outlet to the stern/above the Nav Table. I tried a new GFI receptacle - didn't correct the problem. I note here it would have been nice if Catalina had put in a couple of inches of slack in these wired. It was a RPITA to get them disconnected and connected again (I did take the time to label LOAD and LINE). I then just disconnected the wires at the OUTLETS breaker and then put them right back. Presto - everything worked just fine. One presumes some corrosion built up over the last 15 years. Don't know why the outlet to the stern/above the Nav Table worked throughout.
