Antenna whips
Bob S
Sep 27, 2007
1,774
Beneteau 393 New Bedford, MA
So we finally got hauled. when we un-stepped the mast I found the stainless whip was missing. I have no idea how long it has been this way. It’s a Vesper VA 159 AIS/VHS antenna and both my VHS and AIS worked all season. My question for the antenna gurus is, can I replace it with the correct diameter (I believe 3mm) piece of SST? I was thinking of a piece of SST welding wire. Not sure if they are made of anything special. 2020:banghead:
Feb 17, 2006
5,274
You can by whips off of ebay. I did that for some HF whip antennas I had. Just in case I cut them too short. I would think that if you use anything other than an antenna whip, it might look like a coat hanger on your 74 Ford.
Sep 25, 2008
7,099
Alden 50 Sarasota, Florida
The trick is picking the correct length if you don’t have the old one to compare. While the resonant length is easy to calculate, the base loading coil length varies between manufacturers which changes the physical length of the whip. If there is no loading coil, it’s straight-forward.
Likes: Ken Cross
Bob S
Sep 27, 2007
1,774
Thanks Brian
I have access to 300 series Stainless in many sizes and was more curious what they are typically made from.
Bob S
Sep 27, 2007
1,774
Don
I did a Wikipedia search and saw the explanation of length. I will get in touch with Vesper.
thanks!
5,274
Vesper might also sell you a replacement whip. Might be a little higher in price than a generic whip. Your call.
Bob, my experience with Vesper has been excellent... Just remember they are in NZ, different time zone and day, which can make the response time little confusing at times.
Bob S
Sep 27, 2007
1,774
I got in touch with Vesper and I can get a replacement whip for $35. But it’s another 35 for shipping. I can get a new antenna from Defender for $89 (cheaper if I wait for the warehouse sale in March) or a 3 foot piece of 3mm 316 SST for $16.76 from McMaster Carr.
Anyone see a problem with the 3’ 3mm from McMaster?
Feb 17, 2006
5,274
It depends on the actual length of the original whip. Do you now the model number of the broken antenna? Most are 36" so it shouldn't be a problem. As I mentioned, I replace my whips with generic whips and had no issues. So the worst that could happen is it won't work as well as the real antenna. I don't think that will be an issue. Look up you antenna and see what the sales brochure says. If it indeed says 36" whip, then a generic whip will work.
Now for the potential show stopper. If you cannot get the old whip out of the base then all this is moot. Check to make sure you can remove the set screw and remove the carcass of the old whip. If you can't then you will need to replace the entire antenna.
Good luck
  • Helpful
Bob S
Sep 27, 2007
1,774
Thanks Brian. The antenna is new, just installed earlier this year. When we unstepped the mast the whip was missing? The nut and collet are still there. The antenna is 1 meter 3.33' but I think this included the coil base. I don't know when it was lost but I had no problem with the VHF or AIS all season.
:yikes: that you know of. Perhaps you had use but I am guessing that with the whip gone your range should be limited.
Your Vesper software has the ability to tell you the antenna VSWR.
For a radio (transmitter or receiver) to deliver power to an antenna, the impedance of the radio and transmission line must be well matched to the antenna's impedance. The parameter VSWR is a measure that numerically describes how well the antenna is impedance matched to the radio or transmission line it is connected to.
Likes: Ken Cross
Bob S
Sep 27, 2007
1,774
You're probably right as I have no idea when we lost the whip. Could have been my last cruise??? Either way, replacing it is turning out to be a project.
Every thing "boat" is a project, and a learning experience for me.
Likes: Bob S
dLj
Mar 23, 2017
3,431
Our society has become a use and throw - building and\or working on things from a fundamental level is now becoming further and further from our perspectives. Boats have never arrived to the "remove component X replace with new" type mentality that the majority of our society has grown used to. This all adds to the feeling of "project" when doing work on boats...
dj
7,099
Go for it. The radio can't read the brand name on the whip.
Just for peace of mind, I'd put a VHF SWR meter or even better, an antenna analyzer on the rig when done to verify a reasonable match. The former is both cheaper and pretty straight forward.
2,405
Hunter 30 Everett, WA
The issue here is once the mast goes up it becomes really difficult to adjust the length for a good VSWR. It would be way less trouble to get the right part or replace the whole antenna.
Apr 8, 2010
1,955
After well over a decade of use the ss whip fell out of our masthead antenna. I found it on deck one day.
Next haulout we replaced the whole antenna assembly. The bottom loading coil was showing UV damage and age.
As Ken tried to point out, it's a looooong way up there and I would add that doing this work from a bosuns chair is not easy.
When the yard did this replacement while the boat was hauled for a bottom job, they used their 4-wheel electric Man Lift, and the guy could work on it up-close with no problem... I got billed for about a half hour of time.
Seemed like a really good deal!
7,099
I understand but you don’t need to wait until after you raise the mast to check.
While height, orientation and proximity to nearby objects will affect SWR, that doesn’t mean you can’t tune it for minimum SWR; only that the minimum you see at ground level will be higher than when erected. Just tune for minimum SWR as the optimum antenna length won’t change.
