I was checking my HF radio on my 26D and found a short at the coax. I had crushed the coax at the base so I ordered and installed 35 feet. Man, what a job that turned out to be! I forgot that the coax and electrical were zipped tied together.
1. Undo the mast deck light, cut off the cable and coax ends at the base and pull it out the old cable and coax thru the top, dragging the new cable up, remove a zillion zip ties.
2. Drag the old cable back up with the new coax.
3. Attach the new coax to the electrical cable with a zillion zip ties and drag them back down with the old coax. Must have made a million trips from the bow to the stern.
4. Attach the coax connectors and test......still has a @#$%^& short!!!
How can that be?? I then tested the antenna, Shakespeare 5215, and it was the bad guy.
O'well, now I have a new coax, new connectors, new antenna and I know that the lights work. So does the radio three hours later.
