I am planning out the wiring for the Link 1000 I bought. The schematic shows one wire running from the positive of the start battery to the control panel of the Link 1000 and two running from the positive of the house bank to the Link 1000 control panel. Is there any reason I can't run these wires from the posts on the battery selector switch to which the cables from these batteries run? This would mean a run of about 6-12" vs. 8-10' of this wire. I realize there may be a small voltage drop from the battery to the switch through the battery cable, but it seems to me that this would be less than any drop that happens in the #18 wire that would run the same distance directly to the batteries. Also, since it would run directly to the post of the switch, it would in effect be connected directly to the cable, meaning that the position of the battery switch wouldn't matter. Am I right about this, or is there something I'm missing?
Attached is a link to the owners manual for the Link 1000, for anybody who wants to look at it. If you scroll down to p. 12 in the manual, you will find the schematic.
