Another thing to watch for on Compac 16s
Jan 8, 2025
179
Compac 16 Pensacola, FL
The compression post attaches with two bolts to the frame at the back of the V-berths. The bolts can wallow out wood enough to let the compression post sag, letting the crown of the cabin flatten a bit. The fix is easy by sistering a vertical brace from the sole up the post. I did this on a 1978 16 I owned years ago in such a manner that I had a notch at the top from which to hang whatever. If memory serves there's an offset that required me to laminate two pieces of 3/4" board together, leaving the outer one an inch or so higher than the inner one.
BTW, I just bought a very clean 1983 Compac 16 to return to sailing after over a decade of being on the hard. We don't own waterfront any more and I'm too cheap to pay storage, so scaling down to the 16 was necessary -- but I loved the '78 and am again happy as a pig in . . . a wallow.
Those are very nice boats and they have a reputation for being one of the easiest trailersailers to launch.
-Will
