Tom
For those of us that want to use the original H26/0 table (large configuration) AND make use of the additional berth space if the table could be lowered, lets put our heads together to come up with an idea... I'll start:1. Remove the support cone.2. Install 3 drop down legs on hinges that can be folded up against the bottom of the table when the table is to be lowered to form the bed. One leg located at the forward (narrow) end of the table, offset so that it can fold up with out interferring with the compression post and keel trunk. The other two could be at the wide end corners, placed inboard enough so that they aren't in the way getting in/out of the settees.OR... (Have to check the measurements to see what is possible)...Fashion a single wide leg for the wide end that is hinged to fold up under the table when it is to be lowered. A shelf or cubby could be hung on it to add a little storage, too.Any other ideas?Fair winds,Tom
