I recently replaced the burned out 110V indicator light on my panel and after doing that the Reverse Polarity light comes on. It goes out when I turn on the 110 main breaker. The old indicator light was neon and the new one I got from Paneltronics was LED so I thought it might be LED polarity or something so I switched the connections but get the same result. Just to be sure I checked with a multi tester and confirmed the hot leg was indeed still the black wire.
I don't know how the reverse polarity detection circuitry works so I'm wondering if the LED is could be causing this or what else it could be.
