Decided to start another thread so as not to hijack @Rick D's, although much of my equipment is the same as his: However, my problem is that SOG (GPS) does not display on Raymarine instrument display unless the AIS is not connected:
Connections: Standard Horizon GX2200 AIS-receive connects to B&G Touch 7 CP via NMEA0183. Raymarine connects to B&G CP via SeatalkNG/NMEA2000 gateway to NMEA2000-to-SIMNET conversion cable.
I called Raymarine and B&G Support separately last summer and they weren't helpful. I was expecting that, once they learned it is a mixed system, but I was hoping for some insight (particularly from B&G) because my theory is that the SOG data packets from the AIS data stream are being relayed and mixing with the SOG data packets coming from the B&G CP, and both are causing confusion in the Raymarine display (like two people talking at once). I was hoping they could help me find a setting that would turn off the relay of the AIS data packets so they wouldn't reach the Raymarine.
Anyone have any tips or insights about this?
- SOG from B&G displays on Raymarine i60 speed instrument display head with GX2200 radio turned off (AIS disconnected)
- AIS displays properly on B&G with GX2200 turned on
- SOG on Raymarine speed display turns to dashes when GX2200 is turned on (unless NMEA0813-out is disconnected from GX2200)
