Another engine mount thread got me thinking about my engine mounts. How do you know when the mounts are bad?. My one cylinder ysm12 engine vibrates the boat pretty good at slow speed. Smooths out nicely when rpms are increased. My boat it on stands which doesn't help matters. Actually vibrated the positive cable loose on the battery causing some arcing and the case melting a bit. This thing is basically a 10hp vibrator. It sounds like the mounts are very expensive. I assume that since it smooths out at higher rpm that they are still good. When they go bad do you hear metal to metal noise since the isolator is bad or gone completely? I guess I will wait until next Spring when I get her in the water anyway.
